henklbr
henklbr
  • Lid sinds 07 februari 2011
  • Berichten 1073
  • 11 november 2016
  • 10:29
WARNING WARNING WARNING -> Before flashing, ACTIVATE PIN in "Secure startup" (You'll be asked for it AFTER flashing!)
This ROM is based on the the latest ROM for Germany (DTM) released 11 nov 16, and made it compatible for the Netherlands (PHN).
This is official Samsung ROM, so KNOX won't be triggered!
Your data will stay intact, but it's possible you get "com.android.phone has stopped" -> Then a Factory Reset is needed (in Recovery)!
What's new:
* November security patches (Samsung Android Security Updates)
* Stability Improvements
Model SM-G935F
Model name Galaxy S7 edge
Country Netherlands
Version Android 6.0.1
Changelist 9519568
Build date Thu, 27 Oct 2016 09:34:28 +0000
Security Patch Level 2016-11-01
Product code PHN
PDA G935FXXU1BPJK
CSC G935FPHN1BPJ1
Download for install with Odin 3.12.3: MegaNZ
UN-RAR the archive and place the files in the designated slots in Odin 3.12.3
This package contains the HOME_CSC of the Netherlands (PHN); if you want the HOME_CSC of your own country/region, download the latest firmware of your country/region and extract the HOME_CSC which you can use with the BL AP & CP of the main package!
Greetzzz, Henk.
Android-version: 8.0.0
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 28 november 2016
  • 09:54
This ROM is based on the the latest ROM for Spain (AMO) released 28 nov 16, and made it compatible for the Netherlands (PHN).
What's new:
Model SM-G935F
Country Netherlands
Changelist 9519568
Build date Thu, 10 Nov 2016 11:35:06 +0000
Product code PHN
PDA G935FXXU1BPKA
CSC G935FPHN1BPK1
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 8 december 2016
  • 10:22
This ROM is based on the the latest ROM for Spain (XEC) released 08 dec 16, and made it compatible for the Netherlands (PHN).
What's new:
Model SM-G935F
Country Netherlands
Changelist 9519568
Build date Wed, 16 Nov 2016 11:35:06 +0000
Product code PHN
PDA G935FXXU1BPKD
CSC G935FPHN1BPK1
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 9 december 2016
  • 08:44
This ROM is based on the the latest ROM for Australia (OPS) released 09 dec 16, and made it compatible for the Netherlands (PHN).
What's new:
* December security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Changelist 9519568
Build date Thu, 1 Dec 2016 11:35:06 +0000
Security Patch Level 2016-12-01
Product code PHN
PDA G935FXXU1BPL3
CSC G935FPHN1BPK1
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 14 december 2016
  • 12:34
This ROM is based on the the latest ROM for United Kingdom (BTU) released 14 dec 16, and made it compatible for the Netherlands (PHN).
What's new:
Model SM-G935F
Country Netherlands
Changelist 9689434
Build date Wed, 30 Nov 2016 23:48:14 +0000
Product code PHN
PDA G935FXXU1BPL2
CSC G935FPHN1BPK1
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 21 december 2016
  • 11:30
This ROM is based on the the latest ROM for France (XEF) released 21 dec 16, and made it compatible for the Netherlands (PHN).
What's new:
Model SM-G935F
Country Netherlands
Changelist 9689434
Build date Thu, 15 Dec 2016 23:48:14 +0000
Product code PHN
PDA G935FXXU1BPLB
CSC G935FPHN1BPK1
Bewerkt (21 december 2016 11:42)
Greetzzz, Henk.
CSC: N950FOXM3CRC4
henklbr
henklbr
  • Berichten 1073
  • 18 januari 2017
  • 14:10
This ROM is based on the the latest ROM for United Kingdom (BTU) released 18 jan 17, and made it compatible for the Netherlands (PHN).
What's new:
* Android 7.0
* January security patches (Samsung Android Security Updates)
Model SM-G935F
Country Netherlands
Version Android 7.0
Changelist 10273029
Build date Fri, 30 Dec 2016 11:24:49 +0000
Security Patch Level 2017-01-01
Product code PHN
PDA G935FXXU1DPLT
CSC G935FPHN1BPK1
Download for install with Odin 3.12.5: MegaNZ
UN-RAR the archive and place the files in the designated slots in Odin 3.12.5
Greetzzz, Henk.
CSC: N950FOXM3CRC4
VinnyAW
VinnyAW
  • Lid sinds 28 maart 2015
  • Berichten 23
  • 18 januari 2017
  • 16:50
Bedankt Henk, daar is die dan.
Ik ga hem er direct opzetten.
Ik zie dat jij hem er al op hebt staan aan je sig. Wat is jouw eerste indruk Henk?
Edit:
Heb hem zonder wipen er zo over heen gezet. Alles werkt zoals het hoort.
Bewerkt (18 januari 2017 20:56)
Verwijderd_Account_155657
  • Lid sinds 04 april 2017
  • 4 april 2017
  • 16:54
Beste Henk, Zou je het bestand nog een keer beschikbaar willen stellen? Ik heb een probleem met Samsung Health op 7.0 en ik lees op verschillende fora dat ik dan eerst terug moet naar de oorspronkelijke 6.0 versie en 'm dan via OTA moet upgraden naar 7.0. De MEGA link doet het in ieder geval niet meer. Alvast bedankt.
henklbr
henklbr
  • Berichten 1073
  • 5 april 2017
  • 20:02
Helaas, deze zijn er niet meer (heb geen onbeperkte ruimte op Mega)
Je zal hem dus moeten downloaden bij SamMobile…
Greetzzz, Henk.
CSC: N950FOXM3CRC4
